Hi guys,
so I realized that my valve cover is leaking so I got to the point where I can move it,
I removed fuel lines, fuel rail, a bracket with harness held by 2 aluminum blue top bolts and the strut tower.
Now when I attempt to lift out the valve cover I got injectors on my way, the harnesses on the top are a little bit on my
way though in this situation the injectors are the main problem, their top parts are blocking me to remove the valve cover
having the harness on top. Here is my issue, I understand each of the injectors has a teflon seal on the bottom it suppose
to be replaced every single time or you would be risking something called "torch effect" as far as I heard.
I got the steel cap covers that these seals been secured with, and so I'm thinking about removing them putting those steel
caps on top and then removing the valve cover. The BMW manual kind a says to do so, although none of the people I
watched videos from have done it. Are you aware of when you/somebody has done the valve cover have they removed
the injectors? please advice
Here is the BMW manual https://www.newtis.info/tisv2/a/en/...1-engine/11-12-cylinder-head-with-lid/OoyW6YD
Surprised to learn you need to remove the injectors in order to get the valve cover off. Have you checked the many videos on this on YouTube? If you have the end caps and apply them as soon as you remove the injectors, and leave them in pace until you re-fit, I think you should be OK.
Thank you for your response. Yeah, I watched those videos and most of them are N54 or 328i and it seems to me they got just a bit
more harness manouver than me on N53. In all honesty I put those caps in the fridge to tighten them up : )
Kind regards
Hi about to take this job on, any pics or tips? Cant understand your injector problem, can you explain please?
