Hi folks, I have a 2003 E46 316i with the N42 engine. It has 90k on the clock, and has been well looked after. Yesterday, I removed all the plastic covers from the engine, and installed a new MAF & coil to cylinder no.2. This may be unconnected, but, when I started the engine with all the plastics off, there is a very distinctive tapping noise that seems to be coming from the top of the engine. The tapping increases with the revs. It is not the quiet tapping noise from the fuel injection, but sounded more like a duff hydraulic valve lifter.
Performance (as much as you can get from an N42) seems unaffected.
I put in a bottle of hydraulic tappet seal rejuvenator last night, and ran the car for approx 15 miles before leaving overnight. This morning, the rattle was gone...initially, but came back after 30 seconds or so, and got gradually louder as the engine warmed up.
There is a noise like a compressor/pump that always comes on when the engine is cold, I may be wrong, but the rattle seemed to start when the pump cut out, which it always has done after 30 seconds or so.
Looking on here, there seems to be several things that this noise could be, either a worn hydraulic valve lifter, vacuum pump, or vanos unit.
I welcome any advise, as I don't want to be replacing expensive parts that don't need replacing.
The cam chain tensioner has already been replaced with the modified one.
