Hi guys,
Is it necessary to remove door panel in order to access all the bolts to remove outside mirror. I removed cover and only 1 bolt is seen so I am guessing there are more underneath the door panel. How many are they?
How do I know If car has memory mirrors without removing mirrors? I will be converting m3 mirrors into CSI and I would like to make sure I order correct base.
There are three screws to each mirror and the door card needs to be removed to access them and also the wiring harness. Also those screws look wrong!
Thanks.
About memory mirrors. If seats have memory than mirrors should have it too? Do all e31 have passenger mirror moving when put in reverse.
