I'm making a plan to supercharge my e46 m52tub28 and now I'm calculating quite a lot of things. I ran into a problem with maf sensor, since i will have more air flow than maf can read. So I have discovered online that I can trick the maf with adding a 2.2kohm resistor and gaining about 400kg/h reading (while changing maf map of course). But I can't figure it out where to wire the resistor??? on which pins?
