1 - 1 of 1 Posts
Hi, I am new on here and looking for a bit of help and advice if possible from the forum users. I also apologise in advance if this subject has already been covered, but I can't find anything anywhere hence my questions.
I need to try to build from standard BMW parts a 1600cc engine that will have enough performance to be competitive in a motorsport class with a 1600cc limit.
So, I am wondering if it is possible to fit an M42 twin cam head set up on to an M43 1600 block ?......using as mix and match all standard components from both engines ie drive and idler pulleys, drive chain, crank sensor, which ecu ? etc. Hope this is enough info to get some feedback started off. Many thanks.
1 - 1 of 1 Posts
