Introducing Hilow from Lowtec: Innovative Coilover suspension, backed by quality German engineering at a price you can afford
Significant advantages of the LOWTEC HiLOW System compared to conventional coilovers:
- more performance due to a constant range of spring – at any lowering position
- easier height adjustment, as there are no additional springs needed
- wide range of height adjustment
- race technology at a reasonable price
Lowtec coilovers are a new and exciting brand for 2011. The design and performance of the Lowtec coilovers are what make Lowtec different from the rest. Other brands still use old technology but here at Made One we believe in change. Lowtec features an adjustable lower mount, something that is still relatively new to the UK market. By adjusting the lower mount instead of the spring collar, a far greater range of height adjustment can be achieved. As a result the car will sit lower and retain a comfortable ride. Hilow kits are designed to lower your vehicle and give it a sporty feel. The damping is approx 20-30% stiffer over standard and unique Zinc-Nickel (ZnNi) processes are applied to the body of the units for ultimate protection against the elements. Lowtec have been established for over 20 years and have a very firm understanding of suspension systems. Great research has gone into the development of the Hilow series. Hilow has been designed to compete with numerous UK brands at various price levels and is built to a very high standard that comes with a TUV quality certificate. We have seen numerous coilovers over the years and the Lowtec Hilow series comes top for value for money. They can only be described as excellent! If you are looking to lower your vehicle without compromise, choose Lowtec.
Hilow H9.1 - Quality coilover for the tuner on a budget.
Shock absorber: Oil-/gas-oil double tube standard
Spring: Adjusted springs for the HiLOW system
Threaded Unit: Cu-Ni-Chrome coating
Bracket: Cu-Ni-Chrome coating
Aluminium Parts: Color-anodized
Additional parts: PU damping bump stop, special dust cover
Stabilizer Tie Rods: Included (where necessary)
Accessory: Pin wrench + hook wrench
Adjustment: Threaded height adjustment in front and rear (where technically possible)
Setting: Standard version with STREET damping and suspension
Specials: N/A
Hilow H9.2 - Mid range best seller.
Spring: Top quality road springs 'Made in Germany/EU', HiLOW system tuned
Threaded Unit: Galvanic ZnNi* coating for a high-quality protection 'Made in Germany/EU'
Bracket: Galvanic ZnNi* coating for a high-quality protection 'Made in Germany/EU'
Setting: Standard version with STREET damping and suspension, alternatively harder RACE version H9.2R
Specials: Enhanced camber adjustment (depending on type), enlarged tire distance - available upon request.
Hilow H9.3 - High-end coilover for fast road / track day.
Shock absorber: Gas-oil double tube premium, high durable race type, single checked and tuned
Spring: Top quality race springs 'Made in Germany/EU', HiLOW system tuned
Threaded Unit: Innovative ZnNi* alloy + black passivation + hard sealing for an extremely durable protection layer 'Made in Germany/EU'
Bracket: Innovative ZnNi* alloy + hard sealing + powder coating for an extremely durable protection layer 'Made in Germany/EU'
Additional parts: PU damping bump stop, special dust cover, closing cap for lower bracket
Accessory: Pin wrench + hook wrench + protection spray
Setting: Standard version with STREET damping and suspension, alternatively harder RACE version H9.3R
Specials: Enhanced camber adjustment (depending on type), comparatively enlarged tire distance; special extra low kits - available upon request.
* At present the Zinc-Nickel alloy system (ZnNi) is one of the most innovative treatments against corrosion in the automotive sector.
Always aspired to even more protection and even longer lifetime of the components, also the big European automobile manufacturers have increasing requirements to galvanic coating.
To fulfill this challenging demand, the Zinc-Nickel alloy gets particular attention.
Buy here now! - www.madeonestore.com
Please note - Kits listed on www.madeonestore.com and below are only a very small selection of BMW products available. We are in the process of adding products. Custom kits available on request - Please ask for details.
Discussion Starter #2
Basic Price List
BMW
BMW 1-Series Springs (E81-E88 - 116i, 118i, 120i) (09.04-) - £168.00 Inc VAT
BMW 1-Series Springs (E81-88 - 125i, 135i, 120d, 123d) (10.07-) - £168.00 Inc VAT
BMW 3-Series Springs (E30 - 316i, 318i, 320i, 323i, 325i, 325e) (83-90) - £148.80 Inc VAT
BMW 3-Series Springs (E30 - 320i, 324d, 324td, 325i) (83-91) - £148.80 Inc VAT
BMW 3-Series Cabrio Springs (E30 - 320i, 325i) (85-93) - £148.80 Inc VAT
BMW 3-Series Cabrio Springs (E30 - 318i) (85-93) - £148.80 Inc VAT
BMW 3-Series Compact Springs (E36 - 116i, 318ti) (94-00) - £154.80 Inc VAT
BMW 3-Series Compact Springs (E36 - 118tds, 323ti) (94-00) - £154.80 Inc VAT
BMW 3-Series Coupe Springs (E36 - 316i, 318is, 320i, 325i) (92-99) - £154.80 Inc VAT
BMW 3-Series Coupe Springs (E36 - 320i, 323i, 325i, 328i) (92-99) - £154.80 Inc VAT
BMW M3 Springs (E36 - 3.0) (92-96) - £170.40 Inc VAT
BMW M3 Springs (E30) (86-91) - £172.80 Inc VAT
BMW 3-Series Springs (E21 - 315-323) (75-84) - £176.40 Inc VAT
BMW M3 Springs (E36 - 3.2) (96-) - £182.40 Inc VAT
BMW 3Series Compact (E36) HiLow H9.2 - £571.20 Inc VAT
BMW 3Series (E46 Coupe+Saloon+Compact) HiLow H9.2 - £571.20 Inc VAT
BMW 3Series (E46 Cabrio+Touring) HiLow H9.2 - £571.20 Inc VAT
BMW M3 (E36) HiLow H9.2 - £676.80 Inc VAT
BMW M3 (E46) HiLow H9.2 - £730.80 Inc VAT
BMW 3Series (E90 Coupe+Saloon) HiLow H9.2 - £730.80 Inc VAT
BMW 3Series (E90 Cabrio+Touring) HiLow H9.2 - £730.80 Inc VAT
BMW 5Series (E60 Saloon) HiLow H9.2 - £676.80 Inc VAT
BMW M5 (E39) HiLow H9.2 - £889.20 Inc VAT
BMW Z3 HiLow H9.2 - £571.20 Inc VAT
BMW Z4 HiLow H9.2 - £624.00 Inc VAT
BMW Z4 (E89) HiLow H9.2 - £783.60 Inc VAT
