I have a 118i sport plus that keeps coming up with drivetrain fault I have had it looked at by three different mechanics and worked out that it’s low fuel pressure. I got the high pressure pump replaced and the fuel lines cleaned but still have the same problem. I have had the car remapped and now being told to get it removed to fix the problem can anyone help.
Vendor
Which year is your car ?
Who Remapped it was it done on a dyno and did it start to do this after the remap ?
Have you taken your car to a bmw special?
BW chiptune
-Tuning BMWs since 1991
-Dyno Dynamics rolling road.
BW autorepairs
-Over 30 year repairing BMWs.
-BMW Ecu repairs.
UK
0208 561 1818
07831 103030
Unit 8&9
alpha industrial estate
Clayton Rd
Hayes
Middlesex
UB3 1BB
or
Spain
Orihuela Costa
+34643890040
+447831103030
It’s a 15 plate.
Remap was done by mwr performance and no it wasn’t put on a dyno. It started doing it about 4-5 months after the remap and yes I have just got it back from a bmw specialist and he said get rid of the remap and see how you get on.
