My, car never goes goes 55c, was going to change thermostat. Can I buy the thermostat without the housing?
Most part websites I've checked include the housing
Yeah there's a egr thermostat aswell.Ok, still the same. Your system OBD gets the info from its sensors. If you have an under reading (defective) sensor then it will tell the system what it is reading ( even if it is false)!
Is there a second thermostat in your system? EGR thermostat!
Yeah 80euro from bmw, bilstein same price.Most likely the thermostat but you can test the EGR one .
Take it off and see if you can easily blow through it if you can it has failed.
Personally i would just change both but buy good branded ones or ever genuine not ecp cheap ones.
Also it comes with the housing you can't buy just the stat on it's own.
Yeah I'm only getting around 25mpg going to work which is 15 miles away and irish roads so constantly changing gears. Thanks mateI've not heard about the temp sensors failing before, but both main and EGR thermostats are well known common failures. If the max temp is only 55c then that means both have failed and need changing. One symptom is poor fuel economy, car will do about 10mpg less than it should due to not getting upto correct temperature.
I'll see what's available on the Irish websites.I personally haven't had a problem when i have fitted Febi but i prefer Behr/Mahle if the price is right.
