1 - 9 of 9 Posts
None of the "we can fix your ECU/program your EWS" places are able/willing to touch other modules, so looking for someone with a soldering iron, a steady hand and USBDM programmer to flash my LCM.
Local (SE) or posted, doesn't really matter.
Vendor
Can you tell me which car and year
So you want the processor read ?
BW chiptune
-Tuning BMWs since 1991
-Dyno Dynamics rolling road.
BW autorepairs
-Over 30 year repairing BMWs.
-BMW Ecu repairs.
-EGR programmed to stay closed all the time
UK
0208 561 1818
07831 103030
Unit 8&9
alpha industrial estate
Clayton Rd
Hayes
Middlesex
UB3 1BB
or
Spain
Orihuela Costa
+34643890040
+447831103030
2004 E46, LCM is HW 25 and SW 36.
Essentially, yes, dump the original flash, upload the SW 45 one.
Presumably can be done with USBDM (what I've seen) or Xprog
Vendor
Are you fitting rear leds ?
Yep, LEDs came standard (as well as the sealed xenons that you can’t really repair, ugh).
I am mainly interested in the comfort indicator and some DRL options that are not on CI35.
Plus, it’s a newer FW, always fun
Moderator
PA SOFT 1.4 software may have the capabilities that you require.
No, I’m not after coding the module, I need to flash it via a direct board connection. Completely different
1 - 9 of 9 Posts
