Status
Not open for further replies.
I need to go out and get some milk from the shops, so I went out to the Bimmer a minute ago, got in, fired her up, belted up, stuck it in 1st and reached for the lights switch, turned it to dipped beam... But nothing! The dash lit up, but none of the outside lights lit!
I then put the brake lamps on and checked - they work, same with the indicators, reverse lights and fog lamps!
It is just the front and rear driving lights that won't work.
When I pull the indicator stalk to flash the high beams, that works. But the dipped beams won't go on!
Help!
Status
