1 - 10 of 10 Posts
I have just bought a 2003 5 series 2.5d se,always wanted one,RIGHT problem is, starts fine ticks over fine for two minutes, then starts to judder very bad, but revs stay perfectly still, just rev to 800 and judder stops weird does anyone have any solution thanks, johnibby.
My sisters ford focus was juddering badly and it ended up being the egr valve, its was full of carbon buildup so I took the intake manifold off(egr is integrated in the intake manifold in that car) and cleaned it out and it sorted it out.
But that would usually throw up some fault codes.
had a judder on my e60 503d, put some injector cleaner through it and it went away, smooth running controller error will probably be logged so get a code reader on it
Discussion Starter #10
i will try some injector cleaner first ady had a diagnostic on , nothing showed up, but its a cheapo so might not work on bmw ,what have you got, obd11 i mean, john.
1 - 10 of 10 Posts
