Our car has an intermittent horn and when I say intermittent it either works ok or not at all 50/50.
Horns are ok, fuse must be ok
I think it's down to either when using indicators or turning the steering wheel (this is the current theory, as of this evening but I expect most likely the latter of the two)
This evening I tried disconnecting battery for a few minutes, reconnected and went for a drive for about 2mls, horn worked all the way, turned around horn now not working at all until that is I turn into our road and it now works again.
Advice would be much appreciated
