You'll need either a round pin or flat pin ISO adapter, the older your car the more likely you are to have round pins on the radio, but unless the car is pre 2000 then the only way to be 100% sure is to look!
If you have Nav the radio is in the boot, which will make getting the control module to the front of the car pretty difficult.
