Hello guys,
i would appreciate some help for my problem with INPA/EDIABAS 5.0.2 / 6.4.7.
Fresh Windows XP Prof. installation, i downloaded Ediabas-softwaret you can find here
When i start Inpa and its connected to the car i don't see the black circles which say ignition on, when i chose a submenu (E46 in my case) and try to "connect" i always get Error "IFH 0003" (connection problem with interface).
What i have done is:
- fresh installation from link above, instructions followed
- my FTDI-chip-obd device is listed in devicemanager on com port 3 as "serial-usb", drivers installed, in obd.ini in windows-folder i have edited it to port 3.
- in ediabas.ini i wrote ip 192.168.68.1 and port 6801, STD:OBD is activated
- windows firewall disabled
- i did obdsetup.exe in ediabas/hardware, it says drivers are installed successfullly. FIFO-buffer is active and forced in registry.
- path in windows is set correct.
I start it with inpaload.exe
When i connect the interface to my car, the red LED lights up. I tried OBD 1 and OBD 2, my car (E46 1998) has both.
In INPA under "ECU-Path", "Ini-Path" and "Interface" there stands just "?????????????????????" .... normal?
What should i try now...?
Daniel
Hi guys, sorry old thread and all but better than starting a new one, I am at my wits end with this, My attempts to get this working are all but completely futile... I have had 0 success in getting INPA or NCS or anything to read, I have same issues as OP but the fix that worked for him does nothing for me, my car is an E39 2002 525i MSport. If anyone has any ideas please because I am literally at the end of my witts with this and pretty much cant even look at the car without losing my temper. I will happily let someone remote access the laptop also as its only for these sorts of applications so PM me please.
thanks in advance.
