Hello guys.
So.... some of you may know from my previous posts on the possibility of a cracked exhaust manifold that i may have..... well.... it aint! It turned out to be a cracked EGR pipe from the egr cooler to the manifold.
When i was installing the main stat, i moved the egr cooler out of the way like an idiot while its pipe was still screwed in and it wasn't by a bit either so i deffo must have caused the issue.
Bought an exhaust manifold for nothing. May be i should save it just in case the current manifold may crack which is a possibility according to research stats.
Anyways for those trying to install the main stat, just be careful with the egr cooler and dont try to move it out of the way while its pipe is still screwed into the manifold. The egr cooler i have is the one with the pipe welded as part of the cooler so i cant simply by the little pipe, have to buy the whole cooler.
Just a little update for you guys.
Thank you to those who have helped.
Ibby.
Ibby.
