Not sure if this will apply for 4 doors too:
Here you are gents:
http://www.youtube.com/watch?v=fjXSvn3YZ7s
Here you are gents:
Copper doesnt corrode like steel. Thats why copper is used for home plumbing :thumbsupgreat video - but would have been great if the video was filmed by a helper while the job was actually being done.... and not just a clip showing the underside of a e36 ..
also just a thought but I thought that copper exposed to the elements is not great, thats y BMW and most car manufacturers use under body seleants/protection for breaklines etc
....but hey great dedication
you will find that most manufacturers put a lifespan on anypart and aslong as it can reach that lifespan then its ok. there are far to many variables involved with things like this, for instance you mention about being exposed, there is no way to have an average lenght of time in wich a certain part will be exposed due to cars being manufatured for different parts of the world, for instance the x5 and z3 were originally built in the us where they use us grade metals etc but they are sold all over the world, this is where the lifespan part comes into it, aslong as it can meet that lifespan target then its ok, as with most things you expect them to wear down over a period of time this is made even worse with todays attitude, everything is throw away so it dosnt matter if it lasts 5 or 50 years aslong as they get their moneyMMmm true but home plumbing is not exposed to the outdoors and if its is - its covered with foam insualtion pipe padding to prevent mainly freezing, but on a vehicle espcially underneath the car wheres theres always water mud ETC, it may not rust but over a period of time it cant be great.
So easy to see why vehicle manufacuters including BMW dont use exposed copper,,, however copper breaklines are ok , its just the newby is new , coating the exposed pipes would have been the way,,,
even in home plumbling , and corgi plumbers dont leave pipes exposed they are normally painted, its not only a cosmetic issue but a safeguard
So the newby has done a great half job... which I dont thinks gonna be great for the another newbi who wants to replace break lines.
Also BMW's are not about micky mouse fixes, the job may be done (half done) , and the breaks will probably be ok , but its just work you expect on a FORD or Vauxhall and not a Bimma.
one more point Why do vehicle manufactures spend quite a bit of there profits on research,
In other words why do BMWs leave the factory with this protective seleant on the breaklines????
We use Kunifer :thumbsup bends really easy and has good corrosion preventionIve got a feeling the pipe is a nickle/copper alloy.
Doy you use copper pipe ronnie? :thumbsup
