1 - 1 of 1 Posts
Hi hope someone can help..
My heaters / blowers stopped working suddenly, then intermittently, when they do come on the blowers are running irregularly and you can hear the constant changing in speed of the blowers, also the temperature seems very hot when temp set at auto and 22c. Strangely what I discovered was if when starting the car and the blowers aren't working if I floor the accelerator when driving the blowers will kick in, annoying as not always possible and it doesn't work when flooring accelerator when just idling.
I have read that the blowers may be effected by a failing / low battery, given the above info would you surmise this is my problem or something different.
Thanks ...
1 - 1 of 1 Posts
