thanx for the link a20.
Right first things first THIS IS NOT A ONE MAN JOB. I have a mate who is built like a brick shit house and he had removed and fitted his hardtop a few times but then the enevitable happened. He lost his grip and dropped it and smashed the rear screen, My advice is always get a freind to give you a hand.
To remove the hardtop you need to first put down all the windows and then release it from its four connection points. To start off you should unclip the windcreen mounts first, These are located under the sun visors and when you push the the dark square bit next to the long lever it will cause the lever to pop out a little bit, you then pull the levers and the front is released, sometimes you need to push these buttons hard as they can get stuck a little. once the front has ben released go to the back and push in the compartment covers located under the rear lights. the flap will flip open and inside you will see a red lever. Pull the red lever towards you and it releases the rear end, pull this lever as far forward as you can towards the front of the car and then get a mate to help you lift the hard top off.
The hardtop doesn't always come out first time as it requires the red lever to be in an exact location to allow the pins to come free. If this happens just move the red levers a little bit whilst raising the roof and it will pop out.
The roof is heavy so get a good grip before attempting to lift it off.
When you decide to refit the roof first locate the rear of the roof into the pin holes and then do the front. Lift the levers on the front to line up the front end but do not close the front clips first. Push the red levers in first so the back is secured and then push in the front levers.
I have removed and refitted my roof many times and I have found this mesthod to be the best and easiest.
All the best mate, if you struggle pm me your contact details and I will call yo as soon as i get the message. It is a very simple procedure so I cannot see you having any problems. Once you've removed it and fitted it once it will become a piece of cake.
Best of luck mate.
