got a 320d 2007 plate and just had to change 2 rear tyres as inside wall down to wire and also a grinding noise but dont think it a wheel bearing , anybody got any ideas what might be my problem
Need more info on the noise. is it when you apply the brakes or does the tone change with braking. Does the frequency of the noise change with speed or when cornering? Does the noise change from start up to full running temp? can you describe the noise or relate it to something? is it from the front, rear, near or offside?
Broken suspension springs? Tyre wall down to wire? really? sounds like a good look is required lying underneath with it on jack stands and rotating the wheels.
