1 - 20 of 27 Posts
When I drive in D it sometimes jerks then goes into limp mode and can only move in reverse, but if I clear it then only drive in s d then it fine and fine going in to neutral and reverse and completely stay out drive other than passing it to get to another Comes up 48 in white one you can't see then rest in pic other than that it's running fine it seems
Sent from my SM-T725 using Tapatalk
What age is the car.
Has the box hd an oil/filter service at all.
A fault code scan with bmw kit will be of help.
yeh,,get adaptions read,,then send them to zf,,my foxwell can read adaptions as can carly etc,,,zf will send you results,seen it done,,my guess is on low fluid or clutch E at fault..check gearbox for signs of leaks,its common if not been serviced,although if you had of searched the forum you would have read this.
Got these ones this morning in s d which never happens but seems when driving slow maybe clutch slip would be my guess maybe, The gear box was not long out but garage said they couldn't find a problem with it so assuming they put new filter and oil in it.
Sent from my H3113 using Tapatalk
2002, I'm going to try get my friend to scan it as he has it I just have snap on one
Discussion Starter · #6 ·
Gear box has already been out but garage said they couldn't find a problem
Discussion Starter · #7 ·
When gearbox went back in I reset gearbox so has to learn again and was fine for while as garages machine wouldn't do it cheap shite then come back again but need to get my mate for bmw one
Discussion Starter · #8 ·
It's been fine for few weeks this is first time out in rain today and if I mind correctly it happened once in car wash too maybe just a coincidence
its aint just a case of dropping and and refilling,its quite a comlpex procedure
Discussion Starter · #11 ·
I'm not a garage so can only go by what they said all I know is they had it out etc and couldn't find a problem and put gear box back in and was fine for past month dry days out but it did come up when washed it and today while raining not sure if just coincidence or not but what I do know is I have a problem
this is what im wondering,,did they go through procedure,,thats if the 5 speed zf has same sort of procedure as the 6hp and 8 speed etc,,
Discussion Starter · #16 ·
Did anybody check if the oil is full in the box after putting it back.
One would assume that's procedure but who knows these days with garages cutting corners, I sent message to ex bmw specialist he's going to have a look at it and give the car a going over and plug in bmw software and tell me what exactly needs done once he's back from holiday has some time free as his garage is always busy he comes back on the 1st then he's booked up for a month or so, so a little wait but least it will get proper care and some one that knows the car inside out
Discussion Starter · #17 ·
Yeah I'm not sure where does everyone buy there clutches from was thinking of new ones if there going to strip down etc makes sense while at it
Discussion Starter · #19 ·
Not sure if anyone else near me he seems to know his stuff anyways better than last guy anyways
Sent from my SM-N986B using Tapatalk
zf have a website of approved specialists,you go to it and put ya address in,gives you nearest one,and a firm price of the job,,ie gearbox service is routine price,,theyb say ?£400 and thats what u pay
1 - 20 of 27 Posts
