Some of you may remember a while ago I was trying to find a solution to carry my bike on my 435 convertible. After looking at many different options, the only realistic solution was a towbar - I already had a bike rack which I used with my wife’s car. Found very little online about anyone that had fitted a towbar to a convertible, but here are the results, which I’m very pleased with. It’s detachable when not in use.
T
Ok, so let’s have some details then ��
I want one on mine, which make, how much and who did it would be useful, as well as any issues...
J
J
T
Hi Tony
can you please confirm which lights should work on the above cycle carrier. I have just purchased on and connected to my brother's tow bar to check it out and the headlight and brake lights did not appear to be working. I'm wondering if they should work (I would have thought so ) so are mine faulty, or is it just a case of them not working on my brother's car but would potentially work on mine when I get a tow bar fitted with a "7-pin Vehicle Specific Wiring Kit" ?
Theresa
Your car has likely LED lights, if the lights on your lightboard are standard bulbs it's likely/maybe that the mix is messing with the BMW systems. If you have a vehicle specific wiring loom fitted it might help...or not.
Micky
