1 - 10 of 10 Posts
Premium Member
I couldn't find any DIYs online for this pretty common issue, so I thought I'd create one on Bimmerforums. I'm sure this guide will apply to any BMW model that uses the N13 engine setup.
Right so over the past month our F20 116i has intermittently shown us a drive train fault message on the iDrive - wonderful.! It wasn't overheating, running rough, in limp mode or anything. Strange.!
Vehicle Car Electronics Technology Electronic device
Electronics Multimedia Car Vehicle Technology
A quick scan on ISTA+ produced fault code; 20A608 - Turbocharger - coolant pump, actuation. Pump blocked.
Screen Text Font Multimedia Computer monitor
This is a small electric coolant pump which provides cooling to the turbo, possibly when it's very hot and when you turn the engine off to stop damage from heatsoak. Shame it failed after only 43400 miles / 69850 km..
Here is the parts diagram from RealOEM. The pump cost around £70 from my local stealership - Part No - 11518616992
https://www.realoem.com/bmw/enUS/showparts?id=1A12-EUR-05-2013-F20-BMW-116i&diagId=11_5013
Tools you'll need.
Ratchet with E8 External torx socket.
Ratchet wobble joint and small extension.
Flat blade screwdriver.
Pliers or hose clamp.
Fresh coolant.
On to the DIY.!
  • First yank up the air filter box from it's 3 rubber mountings. Then unclip the cable that runs along the back of the box.
Vehicle Car Auto part Engine City car
  • Unplug the MAF sensor and open the hose clamp to the air box with a flat blade screwdriver.
Fuel line Auto part Engine Vehicle Wire
  • Lift the air box out of the way and move the cable to one side. Now the turbo coolant pump is exposed.
Engine Auto part Vehicle Car Automotive engine part
Auto part Motor vehicle Tire Automotive tire Pipe
  • Now, open the coolant expansion tank to depressurize the coolant system. If you don't you'll loose more coolant than you need to when removing the hoses.
  • Using some pliers open and move back the 2 hose clamps, then unplug the electrical connection.
Auto part Vehicle Tire Engine Automotive wheel system
  • Next, using a ratchet with an E8 External TORX Socket, unbolt the two M6x16 bolts. The left is slightly under the crank pully, but easy to reach.
  • Now yank the left hose off the pump and catch the coolant, about 1 liter will come out, then remove top hose from pump.
  • Remove old unit from the car.
  • If your car is a manual you'll need to swap over the bung from the old pump. This blanks off a coolant connection used by autoboxes.
Auto part Vehicle Groupset Bicycle part Family car
Auto part Vehicle Fishing reel
Technology Vehicle Auto part Electronic device Wheel
  • Offer the new pump assembly up to the engine block, fit the two M6x16 torx bolts, these only need to be snugged up. Don't be that guy that snaps the bolt in the engine block.
  • Slide on the two hoses then re position hose clamps, then fit electrical connector. Reassemble air box assembly.
Auto part Engine Vehicle Fuel line Car
  • Top up the coolant via the expansion tank and follow standard bleeding procedure.
  • Fire up ISTA and clear fault codes, now you're done.!
Screen Text Software Computer monitor Technology
Vehicle Car Technology Electronic device Compact car
NOTES:
Having inspected the old pump there appears to be no blockage at all, I can only assume failure has allowed coolant into the pump and shorted it.
Hi there,
Thank you for posting this guide. I have a 2011 F20 116i and it started off with showing the same code when scanned even though, there were no physically symptoms. So I tried this and the fix didn’t work. Now that I’ve changed the part over it is still showing the drivetrain error but no code. Has anyone tried it and found no result? Is there anything else I could try?
2012 BMW, 1 Series F20
Recently had the exact same issue on my F20 1 series as well, too bad I just came across this after getting the vehicle fixed at an indy. Cost me a tad bit more to fix of course but issue is now resolved and vehicle working fine (tbh is was working fine before but the error has been cleared). Thanks for posting this, it'll definitely help others out there! :)
Hi there,
I realize this is a old question but maybe my response will help someone else.I believe the coolant sensor in your lower hose is your problem. My 09 BMW 750i n63 would flash a drive moderately overheating message.I replace the aux turbo motor like you and after that didn't fix the warning I tracked down the cause : bad coolant temp sensor in the lower radiator hose. Hope this helps someone!!
1 - 10 of 10 Posts
