Hi,
Im new to this forum and i looking for your help. I have a problem with my f11 for a while now and cant find a way to fix it. The gap between the offside rear wheel and the wheel arch is much bigger then the nearside. I got ista+ 2 weeks ago and tried to do the ride height calibration, which value should be around 630mm on both side is 630 on the nearside so all good but its 660mm offside and even after doing the calibration twice with ista still wont change anything. I also got warning on the dash randomly about chassis problem and go to the dealer to get checked but it's not on all the time. Also the car randomly blows the 30amp fuse of the air pump. Once I change the fuse the pump works again as normal and no warning for a while, then another day I get the warning and the fuse is ok so have no idea whats wrong.
Fault code in ista also doesnt help much, no leaks, sensor linkage moving, pump working.
I was thinking about the sensors on the 2 side of the axle but when i did the height calibration they gave the proper reading so they obviously tell the ecu that the car is running at 660mm which is way too high, and still no sign of dropping the height.
Any help or idea appreciated
