Hello Bimmerforums,
Have been roaming this forum for a while now and have decided to join as i need a little help,
I own a 318i saloon, recently after taking a bumpy road a little fast, the band that holds my backbox on snapped leaving my exhaust hanging from the centre bracket, as a temp measure i used a piece of chain and steel wire to secure it to the brackets. After taking it to a few garages and exhaust centres no one has a clue what exhaust is on there, so basically it defiantly isnt a e36 standard backbox, it looks more like a e30 exhaust from looking in parts catalouges.
So my only solution is to replace the exhaust system or fashion a piece of metal to sit where the previous band did, I have pictures if you guys want to see what i'm talking about.
Any help would be appreciated.
eurocarparts or gsf will have the bracket,s you need, or you can make your like i did to fit.
if your handy it,s easy
as there is such a small piece there it is hard to compare other brackets, have sourced a piece of metal and band it back up myself. cheers for the help :cool
