1 - 10 of 10 Posts
is this worth getting? would it help with anything other than wheel nuts? would it come in handy when doing a back bearing change?
340 N·m (250lb/ft) torque
.. with 7/8 inch (22.2mm), 13/16 inch (20.6mm), 3/4 inch (19.1mm) and 11/16 inch (17.5mm) nuts
the torque isn't adjustable.
Personally , i wouldnt buy anything from maplin .The last 3 items i have bought from there have all broken . Last time i never even bothered to take it back .
Compressors and air tool are so cheap now . Only down side is the noise when you run a compressor.
I am building a double skinned sound box to keep mine in this year that way i can use it in the same room its running in .
I was going to get the Ingersol Rand W360 that is in the Snap On video, but after seeing that I may wait and have a look at there new more powerful one, I doubt I will get a Snap On one because no matter what breaks it will cost you £80 to repair
Even if it's just the snap ring that holds the socket on the end of the gun :mad
1 - 10 of 10 Posts
