1 - 14 of 14 Posts
Vendor
UPDATE 8/8/17
I am still getting 15-20 calls every week from people who have sent there water damaged ecu from there non running BMW to ecu testing repair companies who have charged them £50-£80 to look at it (30 seconds work to see its water damaged) and then offered the customer a cloned replacement ecu for £400-£600 that will not work
IF YOU DONT POST ON THE INTERNET HOW AND WHO YOU HAVE BEEN RIPPED OFF BY THESE COMPANIES AND HOW THESE COMPANIES WILL NOT GIVE YOU A REFUND AFTER YOU HAVE SENT THERE CLONED ECU BACK
OTHER BMW OWNERS WILL HAVE THE SAME PROBLEMS AND THESE COMPANIES WILL CARRY ON DO THIS TO OTHER BMW OWNERS
UPDATE 20/11/15
ECU DOCTORS & ECU TESTING COMPANY
WILL CHARGE YOU £50-£80
JUST TO OPEN YOUR ECU TO TELL YOU THEY CAN'T FIX IT AS ITS BEEN WATER DAMAGED
I WILL LOOK AT YOUR ECU FOR FREE (YES FREE)TO STOP THESE COMPANIES RIPPING CUSTOMERS OFF AND TAKING YOU FOR A RIDE
I WILL NEED YOU TO PUT YOU NAME AND CONTACT DETAILS ON YOUR ECU BEFORE YOU SEND IT
SEND TO THE ADDRESS BELOW WITH
ATT CHECK MY ECU FOR DAMAGE
JASON PLEASE
We have been having a lot of 1st time customers sending us there DME or DDE ecu's after they have sent there BMW DME or DDE ecu to other ecu doctors or ecu testing company's only to be told by all of them that they can't repair or offer a replacement ecu and the only option is to buy a new ecu from the BMW dealers and have them program the new DME or DDE
Out of all the BMW DME or DDE ecu's we have been sent where the other ecu doctors or ecu testing company could not fix or offer a replacement ecu
we have been able to offer a 97% repair or replace BMW DME or DDE ecu that's works 1st time
On the other 3% we have been able to offer a tow in drive out in house option on the same day
So that's a 100% of faulty non runner ecu's we have had in that we have repaired or replaced to get the cars working that others can't fix
This has also included water damaged ecu's on the e90 318i 320i 318d 320d 325d 330d 325i 330i 335i
We can offer repair or replacement sent back to you to start your car with the correct hardware and software and the cars info for your car or a tow in and drive away option For your BMW ecu's if needed
This can be at any BMW dealer or BMW independent that has autologic or dealer diagnostics around the world
We are BMW independent specialists
We also specialise in BMW ecu testing,repairs,programming
We have stock of replacement new and Refurbished BMW ecu's ready to program by any autologic BMW user or BMW dealer which makes it possible to tow your can in to a garage and drive out the same day across the world
When other ecu doctors or ecu repairers and ecu testers can fix your cars ecu we can
Bwautorepairs
bwchiptune
Unit 8 & 9 Alpha industrial estate,
clayton road,
hayes,
middlesex,
UB3 1BB
07831103030
02085611818
Sent from AutoGuide.com Free App
Vendor
Discussion Starter #2
Vendor
How I will be in barbados with johnathan still at the end of the month tuning cars for the sol rally 2014
You can what's app me on +447831103030
Bwautorepairs
Bwchiptune
Unit 8-9 alpha ind est
Clayton Rd
Hayes
Middlesex
UB3 1BB
Jason Bw
02085611818
07831103030
BMW Servicing & Repairs
Programming & Coding
DPF Regen & Repairs
Alpha N Tuning on M Cars
Performance tuning Remaps & chips
Dyno Dynamics Rolling Road Tuning
Refurbished BMW ECU's & repairs
E90 Water Damaged Ecu replacements in stock
EWS removal abs dash signal deletes
Vendor
Hi, sorry for bumping an old post but I just wondered if you still offer this service? I've got a suspect DME on my 335, the car runs absolutely fine except the oil level sensor shows as inactive. ISTA only shows a 2E7C BSD Comms Error code. I've reseated all connectors to the DME but still no change. A few people in the forums have recommended replacing the engine earth lead as that solved this odd error for them. I'm going to replace the earth lead on the engine but if that fails i suspect its the DME at fault. Have you ever seen this problem before? Damn those electronic dipsticks! :)
Vendor
Yes if it's water damaged
But if you bring your car down to me I can fit and program one of my refurbished units for your car to prove if it your original Ecu cause of your problem
Which year is your car
Repairing bmws for over 30 years
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW Ecus
0208 561 1818
07831 103030
Hayes
UB3 1BB
Vendor
Discussion Starter #9 (Edited)
Another person getting ripped of by a well know ecu testing compony who supplied a second hand ecu that had just been painted
http://www.bimmerforums.co.uk/forum/f69/hello-everyone-t487041/#/topics/487041?page=1
We supplied the customer with one of our refurbished ECU which he programmed to the car without any problems
The ecu company who supplied him the secondhand Ecu has only offered to give him back £200 (1/2 of what he paid them for a refurbished Ecu) if he sent the ecu back
There paint cans must be very expensive
My car won't start so I can't take it to a garage unless I pay through the teeth to get it towed. Problem is I can find a decent ECU Specialist near me (I'm in Birmingham)
I have located the ECU but I am having trouble removing it. I could send it so a specialist if you guys can recommend one.
I'm pretty sure the DDE ECU is at fault as all sensors from it are showing electronic faults and I've checked all the sensors (connectors, wiring etc). I think it's unlikely they all failed at the exact same time.
Can anyone recommend a ECU Specialist who is with mobile, or I am able to send the DDE ECU to (one I can remove it) to test/repair.
Or if anyone can spare a donor DDE ECU I can use to test and I am willing to buy it if it solves my issues. It's just that I don't want to buy a DDE when that it not the actual fault.
Any recommendations welcome
Thanks guys
Sent from my Nexus 6 using Tapatalk
Vendor
Discussion Starter #11
Thanks guys
Can you tell me which car you have including year and if it's a auto or manual
BW chiptune
BW autorepairs
New and fully refurbished BMW Ecus and Cas units
BMW Keys made and cut same day
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used)
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars
DPF repairs fixed without the need of removal
0208 561 1818
07831 103030
Hayes
UB3 1BB
BW chiptune
BW autorepairs
0208 561 1818
07831 103030
Hayes
UB3 1BB
It's a F10 2010 520d Auto, approx 75k miles.
Vendor
Discussion Starter #13
I would not advise you not to send the ecu to a ecu testing company as they will not be able to test it correctly
They will say it's good and take your money
I always advise to test the ecu on a car as testing the ecu on a bench will miss a lot of things needed
Send me a pm with your vin number and ecus numbers
As I might have a ecu where I've taken the immobiliser off so you could fit this ecu and drive it down to us
PM sent
1 - 14 of 14 Posts
