A bit of damage protection really (although i did notice a small droplet inside hanging off the joint between where the roof meets the front once) Anyway I had a quick look at the seal that runs across the centre tonight and it looked dried and white-ish. Also read on here that sometimes the moving parts need a bit of lubing to keep them in tip top order.
So my question is does anybody have any tips on how to do the above and what products to use? I was going to use autoglym vinyl and rubber care but if there's something better out there then i'd prefer use that. Also what should i use on the moving parts?
...bang on cue.
Use some Gummi Plege on the seals. Mark at Autobritedirect sells it. Keeps the seals black and conditioned.
Lubrication wise, they can get a bit dry, I had one issue, but it was covered under warranty.
...bang on cue.
Nothing worse than lack of lubrication.....:shifty:
