Hi folks
I've started to notice that the car will slightly hiccup when power is re-applied during travel. This is most noticeable when the cruise control is active and the throttle re-engages following say, an overtaking manoeuvre, where you take your foot off the pedal to allow the cruise to take over again.
Not sure where to start looking but my first thoughts are a pipe of sorts?
Anyone had this issue?
Hi folks
The car has done 75k and I can get hold of a reader to run a code check. Car accelerates just fine with no interruptions, it’s just when you back off the throttle a little from acceleration and the car retakes the fuel if you like that the problem occurs.
Folks
Code reader is showing no codes in the system, any ideas on what the issue could be and which part to look at first?
