Hi guys,
Can you tell me if o2 sensors are faulty ?
There are 2 faults in ECU
0x29CD
0X3070
What's causing these faults ?
Administrator
You have a misfire on cylinder 1
swap cylinder 1 coil for cylinder 2 coil rescan for fault codes if the code has moved to cylinder 2 then the coil is faulty
If the code stays the same then swap the sparkplugs (same as above if code moves to cylinder 2)
If no joy with the above then you need to do the same with the injectors
I changed spark plugs & ingnition coils. There still something wrong with the car. It's loosing power and acceleration is poor, engine sounds diffrent as well.
Can you tell if this is correct please
