Hi all,
Just after a little help if possible please ? I replaced both thermostats, the Beru controller and all six glow plugs on the missis's 335d about 4 and half years ago. Car has done 120k miles. Used all genuine parts including Beru glow plugs/controller. I check the coolant temp from time to time and noticed a few weeks back that it was slow to get to up temp and struggled to get past 85 even on a long motorway run. Now and again it got to 90 but often dropped straight back to low 80's. I suspect with the lockdown the car has only been shop-hopping and hasn't been run long enough to get to temp. Plugged carly in and all six plugs are showing as down, so suspecting controller again, and I'm also getting a DPF fault which is 00452A, though I have never had any warning on the iDrive regarding the DPF, nor does the car feel down on power or at least I don't think it is. I have ordered a new controller and both thermostats from BMW and I'm planning on doing this over the weekend. Before I start could anyone advise on the following:-
1. I took the car on a motorway run yesterday and sent a regen request through carly. It seemed to be regenerating normally, it said "running" under regen status, the exhaust gas temps went upto about 600 degrees and the soot levels came down gradually over 10 minutes. The regen status then turned to "not requested". However about 15 mins later when I got home this had changed back to "requested", the soot levels were back up at 35 gram (ash is showing 48 grams). Why would it need to regen again so soon after it had just done one? Or is this just an anomaly in the Carly app?
2. I remember reading on here about checking the power supply to the glow plug controller as this can be an issue ? Any details on what to do here and what exactly to check ? Use contact paste ?
3. After what seemed like a successful regen, the 452A fault will not clear. Tried numerous times now. Could this be tied to the glow plug controller fault and might this clear once the module is replaced and functioning again ?
Any help much appreciated
Andy
Andy
