Hi all.
Late last year I had an issue where randomly whilst driving a lot of electrical issues would start to occur.
First the boot open warning would randomly come on and off, followed by the dials on the instrument cluster going down to 0 and coming back to life again in a split second.
This would always be accompanied by a clicking sound from the glovebox (I presume a relay?).
The issue went after stopping and starting the car, and after it happened the second time I realised the car needed to have the earth lead recall doing and presumed this was a symptom.
That got done at the beginning of the year, and I haven't had the issue since until today.
However today there was an electrical smell that came from the glovebox, followed by the ticking sound along with not only the intermittent boot open warning but also the abs light and red hand brake light came on.
I was close to home so I thought I would be able to get back safely and do some fault finding, however after a few minutes the clicking stopped and all of the warning lights also disappeared.
Does anyone have any clues as to what this may be? I'm guessing a dodgy relay but any other help would be appreciated.
Many thanks
Was the heater blower on full? Is the car part of that recall?
Hi mate.
It was on low, I think I had the a/c on earlier in the trip.
The car had both the blower and ground lead recall done in January.
I'd start by checking earth connections at the battery to body and motor to body, and do a drop test on the battery to make sure it's in good condition. Then check any relays you can get to ...
Thanks! I'll do a check through that tomorrow.
I did a fault code check as well:
2020-05-23 18:27:13
3'/E90/2007/Auto / D60M57A0
MOTOR (!) [Engine]
4212 Glow plug cylinder 1, control
4222 Glow plug cylinder 2, control
4232 Glow plug cylinder 3, control
4242 Glow plug cylinder 4, control
4252 Glow plug cylinder 5, control
4262 Glow plug cylinder 6, control
4993 message (STAT_KOMBI, 0x1B4)
ACC [Adaptive cruise control]
No response from ecu
AHM [Trailer module]
CAS [Car access system]
No faults
CCC [MASK / RAD / CCC / CIC (radio/entertainment)]
No faults
CTM [Cabrio top module]
DSC (!) [Dynamic stability control]
D35A No description available
5DBA No description available
5DE1 No description available
DWA [Anti theft alarm]
No faults
EGS (!) [Gearbox]
CF35 No description available
EKP [Electric fuel pump]
No faults
EPS [Electric steering]
FLA [High beam light assistant]
FRM [Footwell module (lights)]
No faults
FZD [Functions centre roof]
IHKA (!) [Air conditioning]
E71A No description available
E71C No description available
JBBF (!) [Junction box]
A6CF No description available
A6D1 No description available
C904 No description available
KOMBI (!) [Instrument cluster]
A3BD No description available
9319 No description available
931A No description available
A550 No description available
A3AE No description available
MRS [Multiple restraint system (airbags)]
No faults
NAV [Navigation]
PDC [Park distance control]
No faults
RDC [Tire pressure module]
RLS [Rain-Light sensor]
No faults
SBSL [Satellite B-pillar left (airbags)]
SBSL [Satellite B-pillar left (2) (airbags)]
SBSR [Satellite B-pillar right (airbags)]
SBSR [Satellite B-pillar right (2) (airbags)]
SFZ [Satellite vehicle center (airbags)]
SINE (!) [Anti theft siren]
9D12 No description available
STVL [Satellite door front left (airbags)]
STVR [Satellite door front right (airbags)]
SZL [Control center steering column]
----- bimmer-tool 2.170-expert -----
When I reset the codes the glow plug faults stayed (looks like the module is gone), but the kombi and junction box codes clear.
