E90 Pre-ici sidemarkers fast flashing
492 views 10 replies 4 participants last post by  rasa golf
#1 ·
Greetings, before 2 days i get a strange error, all side markers (front, side and back) are flashing fast when i turn on left side markers or right side markers, when i active hazzards light speed of blinking is normal, Bimmerlink show some errors but every bulb is working. Today i started a car at morning and everything worked, side markes were on normal speed, after driving 2+ hours and parking car at home, after 1 hour of car not working the error comes back and marker blinking speed was speed up again. I have Bmw E90 2008 Pre-ici from Germany, i was thinking myb gounding somewhere is corrosive or broken( whole week it was raining so myb water somehow ended up inside trunk.) day before errors with markers one bulb for trunk stripes was bad (black and burnt) i replaced it, and when replacing i seen one drop of water on that burned bulb, no corosion in that light bracket was found and no any sight of water was seen. What to look next? I think Footwell module is not faulty because it worked today for 2+ hours without any errors. Do you think myb wires under "harmonica" protection that are connected to trunk are damaged, or gorunding somewhere in boot have a corrosion (water damage) and where to look in boot for grounding to car?
Any thing is helpfull because i don't know where to look next because all bulbs are good and working
Error codes are on photo:
#3 ·
That bulb that was bunrt before errors, pins underneath is black or burnt, i did clean it off by scraping on little, today i will sand it down and prime it back up if contact is low. Where is earth pin for back light or tail light in trunk?, or where is screw that take all earth wires to car body from trunk? I was trying to find it on internet, but only wires that are in the middle from car to trunk they show how to repair if wire is broken. Thank you for comment!
#8 ·
Where do you connect it on holders? I will add pictures of same bulb holders like mine, where is grounding on them or earh?, if you can draw me on photo where to put secound earth wire to it, and when i connect secound earth wire, do i strip earth wire before connector and connect secound wire to that original gorund/earth wire or i need to ground it somewhere else? And do you recomend soldering secound wire to bulb holder or some other way to fixate it? Thank you for respon! I will try to do it today after you respond.
#10 ·
It’s the one with red circle as it’s shared with all bulbs.
I normally use a small self tapper and a ring crimp, drill a small hole in the plastic housing to run wire through then connect other end to a good earthing point on the body
