Might be of use to someone.
I got a pair of Michelin Stealth hybrid wipers which are very good but you cannot refit the arm trim so they end up looking a bit unsightly.
Solution: cut the trim pieces with a junior hacksaw to the full width required, file them square to the depth of the original contours and pop them back on...forgive the scratches they will get sanded and heat gun treated before final fitting.
Hmmm. So what's supposed to be the advantage of 'stealth' over the normal OEM wipers? Not had an issue with OEM replacements so far...
I get you're point - however, these will be quieter when they're worn out, and/or last longer than 30k.
I've never been a fan of the flat types. Only had 3 sets in the past & all of them were noisy, 'horror movie creaking door' like.
