Hello,
Looking for some advice please.
Chain guide was damaged and I've
replaced the chain and guides. Car was rattling after start and it turned that inlet vanos was faulty, replaced.
Timing set with timing tool.
Now on cold start only there's 2 second rattle which stops immediately after and won't come back on another engine start unless it cools down.
Tried to drive it and got smoke from the exhaust and car starts to stall, oil light comes on.
I've checked camshaft sensors and solenoids, these work fine.
Vanos adaptation was reset.
Now what seems strange to me but I cannot wrap my head around it is:
1. Camshaft position doesn't return to its initial position, it stops a few degrees early.
2. Ista vanos adaptation values show:
Inlet - 114 degrees
Exhaust - 60 degrees
Actual position when engine is started reads in region of
Inlet - 125 degrees
Exhaust - 105 degrees
I'm not familiar with this but to me it seems far off.
When adaptation for exhaust side is started while car is running the car will shake a lot and try to bring the value down, it reaches about 60.6 degrees but when adaptation is finished car stops, when started again value is back at 105.
I was leaning towards incorrect timing (wrong tool) however looked everywhere and all tools appear the same.
Any suggestions will be appreciated.
Does anyone know what the starting values for inlet and exhaust should be? Or anyone with same car, engine and with ista could check these values for me please? When car is idling (Vehicle information - control unit list - DME - call up ECU)
Thanks in advance
Inlet - 114 degrees
Inlet - 125 degrees
Thanks in advance
