1 - 1 of 1 Posts
Hello, new member asking for a bit of help! Car e85 3.0 auto airbag lamp on. Fault codes for under voltage on srs page and airbag lamp on instrument cluster page. I can clear the under voltage code but not the airbag lamp code. Using pa soft BMW scanner v 1.4. the cluster has been worked on before as the back of it was missing and the rev needle was resting below zero and got caught up with the fuel gauge needle when turning the car off. So secondhand clocks are plentiful on eBay but I'm not sure of my part no. because the backs missing from mine. If I get a set will swapping my EPROM chip to the 'new' clocks overcome the mileage and vin issues? My car is fairly low mileage so might be tricky finding a set with lower mileage if that matters. I'm in Bognor Regis if there's anyone who's can help nearby. Thanks for reading.
1 - 1 of 1 Posts
