E81 ABS /Speed sensor problem / driveshaft replacement
1 reading
1.9K views 1 reply 2 participants last post by  rasa golf
#1 ·
Hi guys,
I have an e81 with the abs fault. I initially replaced the rear sensors but that hasn't fixed it. On close inspection the abs reluctor rings look like they need replacing. I've heard because of the corrosion that occurs underneath the ring it can then be difficult to get a new ring positioned correctly on the existing driveshaft, so problem continues.
So, I'm looking to replace the rear driveshafts and wondering if anybody here has recommendations on where to buy them from and if anyone has replaced them before, any tips they can give me would be highly appreciated.
Many thanks,
Josh
