Hi there
Both of my off-side 18 inch run-flats are showing bulges in the sidewall - I guess due to pot hole damage :mad
I'm looking to use this as a chance to move away from the run-flats. I would prefer not to replace all 4 tyres if possible so wanted to check if it was possible to move both the near-side tyres to one axle and if so should it be the front or rear.
Also would it be possible to put asymmetrical normal tyres on the other axle?
Cheers in advance for any help you can give me!
Rory
Rory
