Hi. My E61 has been great., I started having issues with it starting after a day or overnight. Following advise from a local parts supplier I changed the glow plugs and then the glow plug module. I have also changed the seals on the head. It did run better afterwards. I also had a garage check out the battery which they say is fine.
BUT still same problem. Once I have got it started it will start first time during the day.
Following advise on the forum I have changed the DDE Relay. Still same problem.
It turns over fine. But doesn't start. I was wondering whether it was a fuel problem but then it would not make sense that after two hours it will start again as sweet as a nut...
Ideas and suggestions welcome. At this rate I will be putting in a new engine in parts at least.
Could be the fuel running back to the tank.
When did it last have the fuel filter changed that would be my start point.
Hm thanks worth doing. It seemed around 12 months but I do a lot of miles. Worth changing..thanks
