E60 530d poor mpg
Tags
mpg poor
5.2K views 12 replies 7 participants last post by  Graham62
#1 ·
Hi all - my first post so go easy on me !
I've recently purchased a 2004 530d se as a family car ,
I gave it a full service and had a Eco map done straight away . I was getting 32-34 mpg on the school run and round town , 40mpg on a bit of a run and 47mpg on a long journey (motorway ) .
For a 3.0 I was fairly happy with that but over the last 2 weeks things have got a lot worse , now 25mpg on the school run , round town and 32-33 on a run .
After a bit of research I came across a few threads all about poor mpg and thermostat problems .
So I got the coolant temp up on the display and set off on a roadtest of 12 miles . Max temp I got up to was 65c , in traffic and dropped down to as low as 54 c on a run even with the heaters off !
I ordered up a new thermostat from my local BMW dealers and fitted it yesterday , bleed the cooling system and set out on another roadtest - gutted ! All that hard work and didn't make a difference !
Same temps as before ....
I'm now thinking of replacing the egr thermostat ,
Only reason I didn't before was that my temps we're so low that I thought it was the main one ..
Any more suggestions. ?
#5 ·
Agreed - change the other stat - its imperative that the car runs at the right temperature.
I also found that a failed glow plug controller affected my mpg adversely
Also ensure there are no boost leaks etc
#7 ·
Update - fitted the egr stat today , bled the system again and ran it up to temp and straight away it was up to 70c , so I went out for a short roadtest , 5-6 miles and only average 18 mph and mpg was climbing fast already and temp was at 88 and did get to 92 .
Chuffed it's sorted and thank you for your input
#8 ·
Hey Davey - check that it holds this temp on the motorway too - it sounds quite weird that your temps still stayed that low with a brand new main stat. If at motorway speeds it doesn't hold 88c then it could be the thermostat in the gearbox oil cooler, if yours is an auto.
Also it's advisable to take it for a long run (30 mins minimum) so that the DPF can regenerate which it wouldn't have been able to previously with the poor stats, so the dpf could potentially be blocked up. :)
#10 ·
Glad you got your problem sorted.
Can I ask a really basic question please and ask how to get the temps up for viewing, and what temps should I be looking for? I've just bought an 08 E61 so just want to make sure everything is OK.
#12 · (Edited)
I think this query has been done to death, but here it is again.
You can get the coolant temperature from the "hidden" OBC function 7.0 by using the instructions at http://www.scoopz.com/m5board/E60_Hidden_OBC_Instructions.pdf.
I was somewhat ignorant about this stuff before I started looking at the various BMW boards, but had sorta noticed that the little bars on the tacho were not going as far towards 5000 rpm as when I got my car, so decided to have a look. On a town/motorway run for 30 mins, temp was 64 - 68 degrees Celsius, which is, frankly, rubbish. Consenus here and elsewhere is 91 - 95 when properly warmed up. Got the famous excessive emissions warning, and insisted on getting the main thermostat changed whilst having the Air Mass Sensor changed (the fault reported by the computer), and now see 93 - 98 and impressively greater range for my ÂŁ30 of diesel per week. Really, the thermostats should scream that they are going duff, but they don't.
Of course, no good deed goes unpunished, and the latest thing is impressive clouds of white smoke and vanishing coolant, no doubt related to the higher pressure in the cooling system. In a just world, this will be an EGR cooler failure, not a head gasket; I'll keep you posted.
G.
#13 ·
And something to add:
I might be pulling this one out of my arse, but here's a theory:
With the car now running at 90-odd degrees coolant temperature, the EGR thermostat has decided to open (at 77 degrees IIRC) and remained open, 'cos it's buggered. This, in turn, has revealed the annoying fact that the EGR cooler is leaking (as confirmed by my local specialist, via pressure test and bypassing the EGR cooling bit), hence the white plume, as if the car is celebrating the election of a new pope. This is good, since it discounts the alternative head gasket blown possibility, which would be v. uncool.
To sum up, white exhaust plume, capable of reminding following drivers of Dickensian London in the fog, car nonetheless running smoothly, but coolant disappearing mysteriously without any visible sign of leaking, then perhaps suspect the EGR cooler before anyone is advised that it must be a head gasket and ÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁs.
G.
