Hi all,
I have just bought a 2003 X5 3.0D which is running out of fuel with around 65mls on the range! Sometimes when it has half a tank it’ll also crank forever and ever before it fires up. I need some advise on what would cause this, I know it would be a sender but which one would it be; left or right? I’ve changed the fuel pump underneath the car and the fuel filter hoping it’d cure the long crank before startup fault with no luck so I thought it maybe a faulty injector until I found that it’s running out of fuel at around 65mls on the range each time and when it runs out it comes up on the dash ‘fuel injection fault’ and it’ll keep this stated on the dash until fuel has been put in and it’s fired back up again. Any advise much appreciated
