Hello. I have just spent the almost the entire weekend stripping back my 2006 x5 3.0d to replace a badly cracked exhaust manifold. I have put everything back exactly as it came off including the order of the injectors however when I try and start it it turns over but cuts out immediately. I have given it a good few goes expecting some starting issues after disconnecting the fuel line however it doesn’t seem to want to go. Am i missing something? I replaced the fuel filter about 5k miles ago as that was causing it to fail to start then. Prior to this the only issue was the cracked manifold and the noise/smoke it caused. I don’t have an OBD reader.
Anybody able to help me out?
Vendor
Did you unplug the the rail pressure sensor?
BW chiptune
Tuning BMWs since 1991.
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE) and Cas units.
BMW Ecu repairs.
BMW FRM repairs.
BMW key blades cut from BMW key code.
Key data fixed for non starters or when theft attempted by making key by obd.
0208 561 1818
07831 103030
Hayes
UB3 1BB
