Hi,
I have a 320ci E46, 2005. I'm looking to replace the Spark Plugs, but am a little confused. On Ebay, there are listings for a set of plugs which are compatible with the model. The problem is that when I do the manual search on the listing, it states there are two different power outputs for the model; 163hp petrol and 170hp petrol. All the listings then say that the plugs are NOT compatible with the 163hp petrol model. Is this right? If so, how do I tell which model I've got?
Many thanks for any helpful answers, Ron.
Check the part number for the ebay item against the part number you get realoem.com for your vehicle. Ebay compatibilty isn't always accurate but if you go off part numbers you cant go wrong
Sent from my SM-G975F using Tapatalk
Many thanks for the quick reply!
Looks like the plugs I was looking at, ARE the correct OEM ones for the car. I'll use that site in future!
Thanks again, Ron.
