Hi,
I recently bought dice kit for my 2004 330cd with factory 16:9 sat nav. I bought the extra cable as the car has factory nav and don't have a clue where it plugs into.
I assume I don't need to plug the dice into the cd changer wiring, instead the sat nav adoptor fits onto the dice control cable and it should plug into the back of the nav unit in the boot.
Unforturtunately the fitting doesn't look the same as any that plug into the back of the nav unit.
Any suggestions or photos would be appreciated.
Colin
The DICE has two coonnection options :
1) CD Changer with a 6 pin and 3 pin plug
2) Piggy backed to the radio with either a flat pin (newer Nav only) or round pin (older Nav and Business head units).
You car will have the flat pin BM54 radio module (the DICE does NOT connect to the Nav computer), so you'll need either the flat pin piggy back connector or the CD Changer connection.
