Hi,
I've had a long running issue with engine stalling, engine management light and error codes.
The mobile mechanic I use fixed the misfire issue by changing (showing my ignorance here) one of the pre-cat lambda sensors (so in the engine bay) and one of the post-cat lambda sensors (so checking the exhaust fumes post-cat?). Ultimately the pre-cat sensor didn't help, but worked once changed for a BMW supplied one.
I was still getting occasional rough running and/or the engine revs jumping up and down when stationary (only for a few seconds to minutes at a time) so the other post-cat sensor was changed. Apparently that's in a closed loop with the other sensor? As soon as either of things (rough running / revs bouncing about) started, the engine management light would come on.
The fourth sensor had been changed less than a year ago.
Anyhow, I just checked the codes and I have the following. The mechanic, by text, has said it's either the spark plugs or coil packs. The plugs aren't that old (3 years old maybe but mileage has been quite low) and I expect they could be checked visually? As for the coil packs....well I've seen adverts for all six at £299......that plus fitting is pricey!
At the other end of the scale I've seen these, would welcome recommendations for decent but not overly pricey sets: Amazon coil packs
Any ideas from the codes? Btw, the engine management light is on all the time. The car drives fine with just 30-60 seconds of grumpiness every 100 - 300 miles.....
Thanks,
Andy
Thanks,
Andy
