Hi, Just bought a 2000 323Ci with electric seats.
Problem is seats will not move, not up/down, not forward back. and seats is in lowest position.
Cannot get to motors or black box under seat.
With no movement unable to get to 5th bolt to get seat out.
Any ideas, suggestions very much appreciated.
If none of the directions work, makes me wonder whether it's a wiring harness issue - connections to the switch panel on the seat all OK? Wiring harness under seat properly connected?
Hi Evog, Thanks for message.
Have checked connections to switches on side of seat, all ok.
With the seat on lowest position can't really get to connections, but main connector to black box under seat seems ok.
Would like to get a feed to motor that operates front/back movement, but no room to get access.
Might seem like a crazy idea, how easy is it to remove seat squab trim, which seems to be glued to lower seat frame edges, to gain access
to motor.
Any further help, much appreciated.
