hey ..
i turn my heaters onto full temp via the climate controll and all i get is cold air from the drivers side no matter what setting i have it on i.e front blowers , wind screen , feet , but on the passenger side of the car the heat is working perfect. the climate controll unit controlls the temp of the full car not the one that can controll left and right side..
Thanks in advance
Does the air blow with the same power on both sides? One is a gale force wind and the other a sogy fart kind of thing.
Also when the engine is running and fully up to temp does the passenger side blow the air as hot as it should or not?
An easy thing to try would be bleed the cooling system. Need a couple of quid worth of coolant and 15 minutes. If there is an air lock anywhere it may be preventing hot water circulating properly...
HTH.
