Hi All,
I went about installing a new door brake on my car as losing one nail was enough from getting squashed by the door. However, when I put the door back together, my electric window won't work anymore.
Initially, the operation of opening and closing the window had reversed when I pressed the switch.. so I thought I must have put the electric motor cover on the wrong way around. I had to remove the cover to get to the door brake...
So I put it on the other way and around.. and nothing. I tried taking it off and putting it back on again, and this time the passenger's side didn't even work as the fuse had blown in the fuse box, which happened twice..
Now I have trawled through posts here and I can't find a same issue. There is no noise coming out of the motor or neither does closing the window from the Car key work either. There was no cracks or loud noises either..
I'm assuming this is the Electric Window Motor? Anything specific to watch out for when installing a replacement?
Thanks for your help!
