Hi folks,
Having some trouble with rough idling and stalling.
The car appears to idle fine until warmed up. When coming to a stop, the car will stall.
Timing chain and tensioner were done by a garage 4 months ago (3 month warranty).
I replaced the solenoid o rings this morning and topped up around 500ml oil. Previously, the car had a slight 'burp' at idle and the code P0139 - O2 Sensor Circuit Slow Response.
After topping up oil and changing o rings, I get the codes: (Torque Pro/£15 obd2 reader)
P0011 "A" Camshaft Position - Timing over advanced
P0015 "B" Camshaft Position - Timing over-retarded
I checked solenoid connections and then switched positions of the top and bottom solenoids. I kept them connected via their original connectors and refreshed the codes:
P0012 "A" Camshaft Position - Timing Over-Retarded
Where do you think I should start? Replacing the o rings was easy and I don't know what could have went wrong during this process to then throw up these codes and have it cutting out.
I have CCV kit on order, plus O2 and crankshaft sensors arriving tomorrow.
Thanks folks.
Thanks folks.
