Hi Everyone,
I drove home last night (2003 / 75k miles) and the dash beeped and I had the traction control and handbreak light on in amber / yellow.
I dropped it to the garage this morning who have read the code 5E20 pump pressure and have said it will be nearly £1000 for a new pump?
The light went out this morning on the way to work but they said that even after clearing it and testing it came back on (in the memory) not on the dash...
Before I do anything (like cry) can anyone suggest anything?
Regards
James
Vendor
If you can bring it down to me I can have a look at it and fix it before you waste your money buying the wrong parts
02085611818
Sent from AutoGuide.com Free App
Thank you. Where are you based and what do you think it could be? It comes on and off now between drives, more intermittent..
Hi everyone, the light now comes on and goes off when you cycle the ignition (sometimes) or sometimes it takes half a dozen cycles to clear it. It seems to come on when I'm driving straight and not when I press the brake??
