1 - 13 of 13 Posts
Can anyone help with this? :confused
Its the drivers side switch unit on a saloon E46, with the rear window safety cut-out button.
I've bought a complete replacement unit but am unsure how to remove the current one, I can't see any fixings to remove the panel around the gearstick.
All help appreciated!:thumbsup
Sorry to steal your post..... is it easy to switch about the wires. On the drivers window button it seems to be wired the wrong way round. So you do the opposite to open and close. No biggy but if its simple i'd like to do it.
Just as an update to this (and a BUMP) i removed the connector but theres quite a few of the small cables going into connector i need to know which on is controlling the front window switch and what it needs to be swapped with.
Any ideas? :confused
I'll get a dayshift member to help you...he has all the wiring diagrams to hand :thumbsup
I'm not familiar with these switches, but it sounds strange for it to be wired the wrong way round.
Anyway , these are the wire details as far as I can find
Pin 1. gray/black......drivers front open
Pin 2. brown/black....earth
Pin 3. gray/red.........locator lighting
Pin 4. gray/brown.....drivers front closed
Pin 5. NOT USED
Pin 6. black/yellow....drivers rear open
Pin 7. NOT USED
Pin 8. green/blue......child safety lock
Pin 9. blue/green......drivers rear closed
Pin 5. NOT USED
Pin 7. NOT USED
Thanks again mate :thumbsup
1 - 13 of 13 Posts
